Due to two bugs that pass through our beta tests, we have just released a 1.07b version.
This version correct a small bug with the shortcut for "edit comment", as well as a major bug that prevented v1.07 from recording.
We also used this opportunity to change the way the 1.07b version converts the old databases from 1.06 (or lower).
Now, the software will import all your datas from the old database, including bpm, phase, automix points, etc...
Since the automix algorithm has changed a lot, it is recomended that you do re-scan all your songs in v1.07b.
If you have installed the first 1.07 version, and already converted your database, you can get your 1.06 database back from the backup made when you installed the 1.07:
Just copy the "VirtualDJ internal database - backup install v107" file over the "VirtualDJ internet database" file, and launch the v1.07b again. (these files are in the "C:\program files\VirtualDJ" directory)
geposted Wed 12 Nov 03 @ 12:36 am
Can you guys update the developers section? I would very much like to see how the new panels-feature is coded.
Thanks
- Jim
Thanks
- Jim
geposted Wed 12 Nov 03 @ 10:21 pm
