Discussion about Traktor Kontrol S8 Screens
geposted Thu 03 Feb 22 @ 8:00 pm
Hope then also for My S4 MK3 coming soon a update . :-)
geposted Thu 03 Feb 22 @ 9:32 pm
No puedo instalarlo en mi macbook Pro 2012 Mojave: Sucede que después de Instalar me indica que ya que vaya a: INTERFACE y no aparece...
geposted Sat 05 Feb 22 @ 6:32 am
This is a skin for the S8 controller, it will not show up in Interfaces, but loaded automatically when you connect the controller.
geposted Sat 05 Feb 22 @ 7:29 am
Is there any way to preview or see the video on the screens??
geposted Tue 29 Mar 22 @ 11:47 am
i have mapped button (37): prelisten
and 4th sampler knob (31)
sampler knob (31): prelisten ? prelisten_pos : sampler_volume 4
(31) e (37) are in S8 hardware manual
geposted Mon 11 Apr 22 @ 9:44 am
Hey, I am not able to get anything to show up on the screens of my S8. I'm using the latest VDJ on my macbook running macOS 12. I've uninstalled and reinstalled the skin, checked the folder to make sure it's there, tried turning it on and off, tried different usb ports, tried turning it on after already having VDJ open, tried changing it from MIDI to HID mode, and a bunch of other stuff. I'm having no success, and am running out of ideas! It's going into a usb to usb-c adapter, and I've tried it with a different "brick style" adapter as well.
Is anyone able to help me with this? Support for the S8 is so new that I don't see anyone having this issue.
geposted Wed 03 Aug 22 @ 8:12 pm
The skin is auto-downloaded and auto-installed when the S8 is detected. Not sure how you installed/uninstalled , manually ?
Does it work as a controller and it's only the screens that dont work ?
Try to install Traktor (or just Native Access), no need to run of course. I believe some files are missing from VDJ to see the screen device.
geposted Wed 03 Aug 22 @ 9:35 pm
I also cannot get the screens to work. Have updated everything (VDJ and S8 firmware) and the skin is installed, but the screens just display "TRAKTOR" on one, and "KONTROL S8" on the other, like they're not receiving any inputs. There are no unknown devices in Windows device manager.
The controller itself works beautifully with the mapping, just no screens.
Anyone had any success resolving this?
geposted Tue 20 Sep 22 @ 9:01 pm
Not works
geposted Thu 01 Dec 22 @ 9:53 pm
This WAS working for me, but does not seem to be working on the latest beta version with the new stems? Anyone from the vdj team that can help us out here?
geposted Mon 05 Dec 22 @ 9:35 pm
Ok I solved it, dumb solution. You need to install Traktor on your machine. Dumb requirement for using a controller in Virtual DJ, would love for the dev team to fix that if possible. I had to steal Traktor, but that's how it goes I guess.
geposted Tue 06 Dec 22 @ 4:52 pm
you don't need traktor, but you do need the kontrol editor as that holds the driver.
geposted Tue 06 Dec 22 @ 5:13 pm
Hello there ,
i have a TRAKTOR KONTROL S8 ,
Can i Use Completely from my device on Virtual DJ Latest version ?
geposted Tue 02 May 23 @ 12:07 pm
Yes, fully supported https://www.virtualdj.com/manuals/hardware/ni/s8.html
geposted Tue 02 May 23 @ 12:36 pm
Hello everyone, I love my S8 but with VDJ the temperature rises to unbelievable levels (70 - 80 degrees EU) has anyone had this problem?
I use an Apple M1...never had a temperature problem in huge renderings....
Could you help me?
Thanks
Could you help me?
Thanks
geposted Wed 19 Jul 23 @ 12:58 pm
Someone Could you help me? My m1 on 70 degreee Celsius with S8,
What's up?
Thanks
What's up?
Thanks
geposted Fri 21 Jul 23 @ 9:58 pm
What's up?
Thanks
What's up?
Thanks
It has nothing to do with you Controller .
Ist Problem with your Laptop .
Try to check your Cooling System :-)
Thats the wrong Post here for your Problem , try to write your Question in the Technical Forum .
geposted Sat 22 Jul 23 @ 2:36 am
..any update with pad mode?? the waveform restricted and under waveform make 8 pad like Denon Prime Go…
geposted Mon 04 Mar 24 @ 10:55 am
..and now S8 screens have pad 😊
geposted Thu 14 Mar 24 @ 10:37 pm
