Is there a setting where the new 2020 update plays mono out?
geposted Mon 28 Feb 22 @ 11:41 pm
script
mono_mix
mono_mix
geposted Mon 28 Feb 22 @ 11:43 pm
HI,
where do you script this ?
sometimes i use the audio output to mono, is this the same?, using this script can i use both outputs l and r as mono?
thx
thx
geposted Tue 01 Mar 22 @ 1:36 am
custom button, keyboard, wherever script works.
geposted Tue 01 Mar 22 @ 1:57 am
got it ,
thx,
thx,
geposted Tue 01 Mar 22 @ 2:59 am
And how to switch output back to stereo? Send again command mono_mix, or is there command stereo_mix?
geposted Wed 06 Apr 22 @ 3:20 pm
same script, it's a on/off switch
geposted Wed 06 Apr 22 @ 3:23 pm
thanks, and how to show in the skin, which mode is active?
geposted Wed 06 Apr 22 @ 3:25 pm
custom button will be lit when mono_mix is on, for me I just have it switched on with oninit, I always mono mix.
geposted Wed 06 Apr 22 @ 3:33 pm
i have maped it on keyboard and i want prevent unwanted switch to mono... (show mode in the skin)
geposted Wed 06 Apr 22 @ 3:36 pm
i figured it :-) its easy
<button action="mono_mix" class="leftcross2">
<tooltip>Mono output</tooltip>
<pos x="690" y="13"/>
<text format="M" align="center" />
</button>
</button>
geposted Wed 06 Apr 22 @ 3:54 pm
very good, I like it when people get stuck in,
I made my own, because... why not
geposted Wed 06 Apr 22 @ 4:51 pm
