So tonight at the club we set up a Rane Seventy Two and a pair of RANE 12s. My partner‘s laptop was on USB A and mine was on USB B.
He was using Serato and of course I was using Virtual DJ.
So he mixed a few songs and then flipped the switch is over to USB B which is what my laptop was connected to running Virtual DJ.
I loaded up a track and pressed play and everything was fine, and then loaded up the other deck and that’s when deck two started playing super fast.
Even though Virtual DJ could see both RANE 12s I can only control one.
We then switched back to USB A and he loaded up two more tracks in Serato and everything it worked perfect on his end.
We tried the switching over a few more times and Virtual DJ just would not work with the 72 and the 12s.
I ended up having to use Serato which worked perfectly. That really killed my night because none of my playlist are in Serato since I use Virtual DJ.
Is there a setting somewhere that I am missing or is there a special mapping that is needed for two DJs when using the 72 and a set of RANE 12s???
Any help or insight would be greatly appreciated.
I brought the 12s home and I can go get the 72 if I need to. Please I need to get this issue resolved before next weekend.
geposted Sun 06 Mar 22 @ 9:20 am
What RPM setting was the other DJ using ?
Perhaps you had to press the 33 or 45 rpm switch on BOTH units first ?
VirtualDJ has only ONE setting for 33/45 RPM (global, not per deck)
Therefore it's possible that second deck was changing the setting ?
geposted Sun 06 Mar 22 @ 4:21 pm
The same thing is happening with my Reloop Elite mixer as well.....
But Ill check that setting and report back.
EDIT
Both set at 33
EDIT
Both set at 33
geposted Sun 06 Mar 22 @ 6:38 pm
Heres the problem
What is going on?!?!?!
geposted Sun 06 Mar 22 @ 7:31 pm
