How do I improve the pad response time ? I am using Virtual DJ Pro infinity and Pioneer DDJ SZ
Thank you
Thank you
geposted Wed 09 Mar 22 @ 9:26 pm
Check the latency in the Pioneer control panel.
Lower latency gives a better response time.
geposted Wed 09 Mar 22 @ 9:29 pm
Are you sure it's the hardware response time and not some setting you have accidentally enabled in VDJ ?
In which Pad pages you notice the delay ? Hotcues, some other ?
geposted Wed 09 Mar 22 @ 11:41 pm
Thank you
Thank you
Probably just quantized cues.
Try turn off smart cue at the small dot next to hot cue pads in the software
geposted Wed 09 Mar 22 @ 11:46 pm
Thanks. Turning off Smart Cue worked
geposted Sun 24 Apr 22 @ 1:50 am
