Beatport songs are not being imported into automix when they are cued up to play. System often crashes during a playthrough. When I try to edit a mix, the system will sometimes crash during a song I've imported from Beatport. Anyone else having similar issues with Beatport?
geposted Fri 01 Apr 22 @ 3:06 pm
I seem to be the only one then.
geposted Wed 06 Apr 22 @ 12:06 am
Can you try with Early Access build 6886?
https://virtualdj.com/download/build.html
geposted Wed 06 Apr 22 @ 6:03 am
Downloaded and installed. Will report back anything I see in this build affecting Beatport integration.
geposted Fri 08 Apr 22 @ 12:16 pm
Numerous network errors from the Beatport integration. Logging out and logging back in usually fixes the issue, but for a short time. Also receiving "Too many tracks open" errors within the VirtualDJ deck. When moving tracks around in the Automix playlist, VirtualDJ will crash. Waiting for the program to respond will get me back into the application. However that takes 10-20 seconds each time.
When going back to songs on the playlist, I'll get "Unknown File Type" errors. This means I have to restart VirtualDJ, then log out of and back into Beatport.
These issues don't happen with other integrations (Soundcloud, iDJ Pool).
geposted Sun 10 Apr 22 @ 11:31 am
Still getting crashes to desktop as well. Only seems to be when I work with any tracks from Beatport. None of the other integrations I'm subscribed to are crashing the application.
geposted Thu 14 Apr 22 @ 1:08 pm
Now when I add some songs to the autoplay list, they don't play. It's like the graphic information is there but the actual music is not. Also some songs I add to the autoplay list are not there if I reopen VirtualDJ after shutting it down.
geposted Wed 20 Apr 22 @ 12:20 pm
The software has gotten to the point where it is unreliable. Multiple crashes.
geposted Tue 26 Apr 22 @ 8:34 pm
Can you try to rename the Documents\VirtualDJ\Cache\Beatport folder?
geposted Wed 27 Apr 22 @ 5:51 am
fixed the issue for me! thanks
geposted Fri 29 Apr 22 @ 6:37 pm
