HELLO, I HAVE A WISH... I WISH VIRTUAL DJ COULD MAKE AUTOMATIC SHORT EDITS IN A CLICK OF A BUTTON... MOST OF THE TRACKS REPEAT AT CHORUSES THREE TIMES... A SHORT EDIT WOULD CUT THE TRACK AT EXACTLY THE SAME POINT OF A CHORUS TO CREATE A SHORTER VERSION OF THE TRACK... IDENTIFY CHORUS AND CUT TO SHORTEN ... THIS WOULD BE COOL!
geposted Fri 08 Apr 22 @ 6:24 am
Maybe the track cleaner will do?
Its not quite a remix tool, but can cut off "boring" intros and outros, and too many choruses etc
https://www.virtualdj.com/manuals/virtualdj/editors/trackcleaner.html
geposted Fri 08 Apr 22 @ 7:29 am
YES BUT ITS A PROCESS... I HAVE TO SIT AND MANUALLY DO IT... I WANT A QUICK BUTTON... PRESS ONCE AND YOU HAVE THE EDIT... MAYBE THREE OR 4 EDITS!
geposted Fri 08 Apr 22 @ 9:53 am
Just use the stems feature and accapella out.
Its literally as easy as turning a knob.......
You can change the filter in VDJ to either flip the track into an instrumental or accapella. So you could mix in with the intro, let the first verse play then mix out of the hook and turn or press whatever button you have mapped to switch to an accapella.
VDJ makes SOOOOOOOOO easy!!
geposted Sat 09 Apr 22 @ 12:31 pm
