Hi,
I'd like to be able to control these stems :
. Vocal
. Instru
. Beat
. Bass
Right now I'm using the EZRemix eq mode but it's missing the bass.
Would it be possible to put it on the filter knobs of deck 3 and 4?
I tried to map it but I can't figure out how to map per deck.
Thanks
. Vocal
. Instru
. Beat
. Bass
Thanks
geposted Sat 09 Apr 22 @ 8:54 am
action_deck 1 ? ... : action_deck 2 ? ... : action_deck 3 ? ... : action_deck 4 ? ... :
geposted Sat 09 Apr 22 @ 10:50 am
Thanks for the tip on mapping per deck
I tried that :
action_deck 1 ? filter : action_deck 2 ? filter : action_deck 3 ? stem "FullBass" : action_deck 4 ? stem Bass
but it doesn't work
I tried that :
but it doesn't work
geposted Sat 09 Apr 22 @ 11:16 am
Is "fullBass" a stem name ? I'm not sure it is, but it might be.
remember you've also got to specify the software deck if you're wanting if the deck associated with the real slider isn't that deck.
action_deck 1 ? ... : action_deck 2 ? ... : action_deck 3 ? deck 1 stem 'bass' : action_deck 4 ? deck 2 stem 'bass' :
geposted Sat 09 Apr 22 @ 11:28 am
You're right. Fullbass is not a stem name, only fullvocal, fullmelo and fullrhythm.
This works for me :
action_deck 1 ? filter : action_deck 2 ? filter : action_deck 3 ? deck 1 stem 'bass' : action_deck 4 ? deck 2 stem 'bass'
Thank you
This works for me :
Thank you
geposted Sat 09 Apr 22 @ 7:39 pm
Hi,
If I cut the Bass stem with the eq knob first and after I touch the Instru stem with the eq knob the bass will come back fully.
Edit : it does the same if I touch vocals and drums, the bass will go back to normal.
geposted Tue 26 Apr 22 @ 7:34 am
I am not sure what exactly you mean (apologies if I am not answering your question), but the nature of FullXxxx stem control is that once you touch them, they influence other stems in a very abrupt way. So if you turned down i.e. bass stem and then you start doing anything with i.e. FullMelo or FullVocal, the Bass stem is immediately reverted to the center (0.5). I prefer to use individual stems for this reason, I do not use them for isolation, only for muting, and combine them with stemPads for isolation.
geposted Wed 27 Apr 22 @ 5:41 am
Hi Bowie Groove,
It's exactly my pb.
Your method is the 5 stems setting in eq control I guess.
I tried it but how could I have hi-hat and kick on the same knob?
It's exactly my pb.
geposted Wed 27 Apr 22 @ 6:53 am
Hi,
Details are here: https://virtualdj.com/manuals/virtualdj/appendix/vdjscriptverbs.html (check the stem parameter)
The stem is called "Rhythm"
geposted Thu 28 Apr 22 @ 2:47 pm
