Hi all,
Trying to migrate from the loop_out effect to Ducking Echo because the decay is far more natural. But I'm running into a few obstacles.
First, I can't seem to figure out how to make Ducking Echo pre-fader. With loop-out, if my "echo" is going on a little long or a little loud, I can bring the channel's fader down on the mixer and reduce or eliminate it, but Ducking Echo seems to be done post-fader, ignoring the fxProcessing pre-fader setting.
Second, is there a way to make the echo work on video as it decays? Loop Out has a "video" toggle that will make the video loop along with the echo sound. With Ducking Echo, the video just pauses.
geposted Sun 10 Apr 22 @ 12:53 am
Ducking echo is ALWAYS postfader that's how it works.
2 no there is no video ability to any type of echo fx [ducking, echo, echo out] they just capture sound.
geposted Sun 10 Apr 22 @ 1:34 pm
Thanks for the reply. Is there another effect similar to ducking echo that works pre-fader? Loop Out is adequate but the decay just isn't as natural as I'd prefer.
geposted Tue 12 Apr 22 @ 10:37 am
hard to say, what's wrong with echo? a whole world of vsts out there.
geposted Tue 12 Apr 22 @ 10:53 am
no me aparese para descargar el efecto
geposted Wed 06 Jul 22 @ 5:26 pm
