sarebbe molto comodo avere una finestra che visualizza gli accordi
geposted Sun 10 Apr 22 @ 6:54 pm
It displays on deck, next to the bpm .
geposted Mon 11 Apr 22 @ 10:48 am
That's the key, not the chord.
geposted Mon 11 Apr 22 @ 4:44 pm
ci sono molte app che riconoscono gli accordi dei file audio mi domando perché questa funzione non viene implementata anche su Virtual DJ sarebbe molto comodo soprattutto per i musicisti
geposted Sun 01 Sep 24 @ 3:52 pm
You need to post in English here, or use the Italian forum area.
Could you give an example?
bigolingianpaolo68 wrote :
There are many apps that recognize the chords
geposted Sun 01 Sep 24 @ 4:04 pm
To add to what @groovindj has said...those apps that can (potentially) do this are called Digital Audio Workstations (DAWs) and VirtualDJ is not a DAW (at least not in the conventional sense).
If you can list any prominent DJ software that does this we'd be glad to try it out, but realistically, of what use would that be to a DJ/Karaoke set in your view?
geposted Sun 01 Sep 24 @ 6:32 pm
There are many VSTs to detect Chords from a Track .
geposted Tue 29 Oct 24 @ 12:15 pm
I honestly can't understand why someone doesn't see the benefit of chords detection for a DJ set.
2 tracks can have the same key, but different chord progressions. Mixing them won't sound really good. Unless you identify parts of the songs with the same chords and loop one of them.
There are many plugins, but many have a large margin of error, which makes them useless.
I believe if VDJ had this feature, it would be highly useful.
Maybe I'm wrong or I don't understand something. I'd be glad to know what exactly.
geposted Wed 07 May 25 @ 12:49 pm
Exactly, so how would you expect VDJ to perform any better?
I was watching a video recently, showing one such plugin in action. The part detecting the chords was jumping around all over the place, and the key detection wasn't much better.
geposted Wed 07 May 25 @ 1:07 pm
So, you're looking for something that identifies each and every chord in a song? As someone who loves harmonic mixing, I'd think that would be tedious and laborious and for software that already has trouble identifying song keys, I'd think it would be fraught with errors. Knowing the song key should suffice, and if there's a key change in the song, that should be on the user to identify and prepare for.
geposted Wed 07 May 25 @ 1:11 pm
Perhaps if OP could explain what the goal of this feature request is wrt DJing then it may help us to understand.
geposted Wed 07 May 25 @ 1:20 pm
The goal is ability to set several cue points named their chords. Or to save a short sample (4 beats or shorter) and analyze its chord. I believe it would really help to mix perfectly.
I think VST plugins make a lot of mistakes because they work on the fly. Programs and services that load an audio file and then analyze it for a while work much better. There is no need to analyze the entire audio file. This is required only for short sections of the song that are planned to be mixed.
At least it would be nice if VDJ had a tool to analyze the key of a song from a set cue point where I hear that the key of the song changes in its middle. There is no such feature in VDJ either, right? I couldn't find it.
geposted Sun 18 May 25 @ 7:48 am
So I (personally) think capturing a correct key could cover/be a superset of recording a chord progression wrt to mixing two songs - given a "normal" progression in a key, you can mix many other "normal" progressions in the same key and in other keys related via the circle of fifths. There may be example of where this may not work completely well (especially if the progression is weird), but in most common cases of music it seems to work ok for mixing.
I definitely agree with tracking key changes throughout the song though. There aren't many songs in my collection that have a transitional peace, but the ones that do are normally vocal-heavy and powerful songs (e.g. Michael Jackson - Heal The World, Whitney Houston - I Have Nothing), and it would definitely be useful to at least have some representation of those key changes.
Remember though that:
This also doesn't take it adds in complications analysis (errors in detection + enharmonics, more time/processing resources to handle this case).
- A DJ normally wants to make quick decisions based on a summary of info about the track - the more info you have presented may mean a longer time to make a decision
- More info stored per track = more database storage space + processing
Most likely doesn't mean much but if the Key summary captures enough info for like the majority of mixing cases, it's actually a tough sell to add more things (e.g. Chord Progressions)
geposted Sun 18 May 25 @ 1:25 pm
It's still a shortcoming of DJ software, that song analysis typically allows only one tempo, one key and one time signature (4/4) for all music. In all cases it just shows us an average, or the most prominent.
It really should have been a thing from the start (of digital analysis), as the further back you go, the more likely a song will have a varying tempo, key changes and time signature changes.
The UK entry to Eurovision got a lot of stick because it changes tempo - yet the winning song does too!
geposted Sun 18 May 25 @ 1:48 pm
I think its good Idea to analyse musicality of tracks better and more indepth obviously not on the main ui but as an option for people, Ai is probably the tool that will bring that home in the future as its pretty complex. As at the minute Dj software struggles with just detecting the key correctly. I generally use my ears more with keys than I do with the software as it so inaccurate.
geposted Tue 03 Jun 25 @ 9:46 am
