Ok I am using Pioneer DDJ400, master output going through a berhringer uca 222 audio interface into my laptop. So in theory becuse mic signal goes through master output VDJ should pick up/record mic even though it is unbalanced?
Please help
Please help
geposted Wed 13 Apr 22 @ 5:31 am
If the mic is connected to the DDJ-400 this is a hardware only mic (not part of the usb audio interface), and goes straight to the master out of the DDJ.400
(see note at bottom here: https://virtualdj.com/manuals/hardware/pioneer/ddj400/frontrear.html )
geposted Wed 13 Apr 22 @ 5:48 am
So you need to either add a computer microphone (and set mic entry in VDJ sound setting to this mic)
OR, connect the speakers to the DDJ-400 and use that as the sound card instead.
OR, you can route the master output back to a computer line-in, and add a "record" entry in VirtualDJ sound setting equal to this line in.
depends on why you are using the behringer as sound card.
geposted Wed 13 Apr 22 @ 5:51 am
