Topic: Browser_gotofolder error
WWDJdkPRO InfinityMember since 2008
Found a problem with the Browser_gotofolder command....
Was trying to make a custom button that would jump to "Ask the DJ" folder when pressed.
Code was simple:
browser_gotofolder 'Lists & Advice/Ask the DJ'
Works fine when there is no new requests..
Cause the folder name changes to 'Ask the DJ (1)' when the first new request is in.. and the number keeps going up with number of req inbound...
Is there a way to fix it, so the (x) not is a part of the foldername ?
or is there a quickfix to my button code, that would accept any number in the foldername?
geposted Sun 17 Apr 22 @ 10:02 am
browser_gotofolder "askthedj://"
geposted Sun 17 Apr 22 @ 10:05 am
Thanks!
geposted Sun 17 Apr 22 @ 10:08 am
Does not work. Pressing the button opens the Local Music, but this list is inactive. If you specify "browser_gotofolder" any other folder everything works. It doesn't work just askthedj://. Macbook Pro 13 2011, Macbook Air M1
geposted Sun 07 Aug 22 @ 8:11 am
I found out that it broke in version 6921
geposted Sun 07 Aug 22 @ 7:13 pm
