Topic: cant see program
DJJSUPAPRO InfinityMember since 2014
running 10.15.7 on 17''macbook mid 2009 2.8 processor 8 gb ram nvidia geforce 9600gt 512mb
program runs but doesn't display have blue box for screen happened after 2021install i can run old program but djjfx6 wont mapp cant anyone help they say delete set up file but still no fix
geposted Tue 19 Apr 22 @ 10:58 pm
How did you install macos 10.15?
https://support.apple.com/en-us/HT210222
macOS 10.15 is only supported on macbooks from 2012 and later.
In order for VDJ to work correctly it is recommended that you only install supported macOS on your computer.
geposted Wed 20 Apr 22 @ 2:34 am
