I've upgraded to VDJ2021 and I have an issue. When using VDJ8 on my Numark NV controller I could toggle between multi FX select and single FX select by holding the shift button and pressing the Beat/Mode button to do the change. This doesn't work on the 2021 version.
Can anyone please help?
geposted Wed 20 Apr 22 @ 11:20 am
Try set skin3FXLayout to yes in options.
Works then?
Works then?
geposted Wed 20 Apr 22 @ 11:26 am
Thank you so much RUNE, that works perfectly!
geposted Wed 20 Apr 22 @ 11:38 am
