When I was using VDJ8 I had a plugin called ScreenResizer this allowed be to make my videos slighty larger than my screen. Is there anything that will allow me to do this in v2021? I have installed Resizer but that only resizes the window and not the actual video.
If you can solve this for me my day will be complete. It's only a minor issue but I just like everything perfect.
geposted Wed 20 Apr 22 @ 12:16 pm
geposted Wed 20 Apr 22 @ 12:58 pm
Kinda confused. Why would you want the video output to be bigger than the screen resolution/size ?
Could you explain further ?
EDIT, i see you found a solution here.. https://virtualdj.com/forums/246287/VirtualDJ_Technical_Support/Change_Slideshow.html
geposted Wed 20 Apr 22 @ 1:50 pm
