Forum: Addons
Topic: Excel Now Playing Script
geposted Wed 20 Apr 22 @ 9:44 pm
leneerPRO InfinityModeratorMember since 2014
Hello friends, thank you for developing new plug-ins for VDJ;
However, I encountered coding problems in the test. The name in tracklist.txt file is correct, but the display is wrong(random code/messy code) after I configure it in your script,Only numbers can be displayed correctly. Please fix it in time,looking forward to your new works : ).
UTF8(BOM) and GBK(2312) have been tested.
VirtualDJ History 2022/04/23
14:23 : - 冰毒慢摇
14:23 : ?? - ??07
16:54 : 群星 - 05.依然爱你
16:55 : - 05 美人香
17:14 : - 01 你失去了最爱的人
17:20 : - 04 谁说我不爱你
geposted Sat 23 Apr 22 @ 9:37 am
Sorry for the delay.
Thank you for the feedback and details. That is very strange. It looks like a language/localization setting somewhere. I will look into this further.
However, I just programmed a Now Playing application from scratch into an EXE file for Windows operating system. I used it for 2-hours this morning during a show and it worked great. The application does not require Excel - it is a stand alone project. If you can, when it is published, please try that one instead.
Thank you!
Mike
geposted Sat 23 Apr 22 @ 7:26 pm
The exe Addon is available now, but we also kept the old one for Mac users
geposted Sun 24 Apr 22 @ 3:55 pm
I made one of these just the other day for RDS but it runs in app, I might generalise it with a format config file.
geposted Sun 24 Apr 22 @ 5:55 pm
Oh interesting! I didn't realize VirtualDJ was Mac also. Thank you!
geposted Tue 26 Apr 22 @ 8:32 pm
Sounds good. I'm glad there is some activity and interest in this type of app/addon/plugin.
geposted Tue 26 Apr 22 @ 8:35 pm
djefiPRO InfinityMember since 2006
Tries to install the add-on, but does not find it in the extensions
geposted Mon 11 Jul 22 @ 6:49 pm
EL337PRO InfinityMember since 2019
unfortunately I have the same problem
geposted Sun 31 Jul 22 @ 3:12 pm
Use made tools (that are essentially programs) have been removed due to security and practical concerns.
For now, you can contact Support if you really want to use such tools
geposted Mon 01 Aug 22 @ 1:06 pm
Thank you for your answer
Although this solution is not entirely comprehensible to me, I accept it.
Maybe a warning in the corresponding tools would be an acceptable solution?s
I will contact support
geposted Wed 03 Aug 22 @ 12:12 pm
