Everytime I encounter a new install for whatever reason, Virtual DJ AUTOMATICALLY HAS THE PARSE MY FILES AND RENAME THEM TO THIS FEATURE TURNED ON!!!!! YOU HAVE TO CHANGE THIS!!!! I can't imagine any dj or club who would want virtual dj to rename their files for them. So I have to get to the "Parse my files" tick box super fast to uncheck it or else all my files in the current folder are renamed the same damn name with numbers behind them. NO THANKS ITUNES, PLEASE DON'T RUIN ALL THE WORK I'VE DONE TO ORGANISE MY DATABASE!!! I'M BEGGING YOU TO CHANGE THIS TIKBOX TO "NO" SO WE CAN DECIDE IF WE WANT THAT.
Sorry for the all caps.
Thank you,
Alan
Thank you,
Alan
geposted Sun 24 Apr 22 @ 10:14 pm
This setting does nothing to files it is only how they are displayed in the virtual dj database.
File names are only charged if you select rename files specifically.
Tags are only charged if you turn on auto set tags.
geposted Mon 25 Apr 22 @ 4:52 pm
