Hola a todos... Necesito poder guardar los cambios en los parámetros del ECHO OUT FX. Cada vez que cierro Virtual se pierden los ajustes de Delay, Tiempo, Dry, etc. ¿Como hacer para que mis ajustes se guarden?
Hi everyone! I need to be able to save the ECHO OUT FX parameter changes. Every time I close Virtual the settings for Delay, Time, Dry, etc. are lost. How do I save my settings?
geposted Tue 26 Apr 22 @ 3:50 pm
It should already be saved.
Its saved in ini file at /documents/virtualdj/ where the plugins are
If settings are not saving, see here:
https://virtualdj.com/wiki/Settings%20not%20saving.html
geposted Wed 27 Apr 22 @ 9:14 am
I have noticed if you have the same FX open on multiple decks and change one of them the changes made on the one will not be saved.
open it on one deck make changes and close the program it will be saved
geposted Wed 27 Apr 22 @ 11:02 am
or include something in oninit to explicitly set fx params on startup
geposted Wed 27 Apr 22 @ 3:48 pm
