Something is wrong with the new "In Playlist" feature
all playlists are displayed multiple times.
geposted Fri 29 Apr 22 @ 1:32 pm
@Adion
Did you see my error message?
geposted Fri 29 Apr 22 @ 3:12 pm
Not happening here. Do you have favorite folders in virtual folders pointing to the root of the drive or your Documents folder perhaps?
geposted Fri 29 Apr 22 @ 3:31 pm
@Adion, I have found the following
1. Start Virtual and work for a while and "In Playlist" works normally.
2. take a break for about a quarter of an hour and check "in playlist" and everything is in it twice.
3. wait again and check "in Playlist" and it's all triple.
geposted Fri 29 Apr 22 @ 5:51 pm
Great you discovered the cause.. of the multiple entries.. Had noticed, but could not reproduce it. (as restarting VJD removed the duplicates in the search_playlist) Was waiting to report, till I could reproduce it.
interesting that the time to create the duplicates, or triples.. seems to be the similar time required for the Playlist column in the browser info panel to appear, after a change. (have not tested to see if identical)
geposted Sat 30 Apr 22 @ 12:11 am
@Locodoc
hi, why can't I see your message ?
geposted Sat 30 Apr 22 @ 4:38 pm
@Adion
I have now tested with two laptops and a desktop PC (with the 32bit and 64bit VDJ-Version).
The problem with the multiple display "In Playlist" is in all systems, I also deleted the setting.xml and started with new settings, the problem remains.
I can't understand why this is only happening to me, otherwise there is no feedback about the problem!?
Greeting Werner
Greeting Werner
geposted Sat 30 Apr 22 @ 5:05 pm
Did find it now. It was indeed occurring after repeatedly using the function over an extended period of time.
It will be fixed in the next update
geposted Sat 30 Apr 22 @ 5:06 pm
@Adion
alright thanks!!
alright thanks!!
geposted Sat 30 Apr 22 @ 5:09 pm
@Benz Werner
raised level message not directly related to your problem but, a little related to these popups.
geposted Sat 30 Apr 22 @ 5:28 pm
Hi Adion, how far are you with the error correction "In Playlist"?
geposted Fri 06 May 22 @ 1:59 pm
The "In Playlist" function also has an error in the new VirtualDJ version 6954!
System 1 delivers everything.
System 2 with all the exact same settings does not deliver any results.
geposted Tue 24 May 22 @ 5:19 pm
@ADION
The extension "In Playlist" in the new VirtualDJ version 7059 does everything but not what it should. Please check all functions!!
It works like nothing
geposted Wed 03 Aug 22 @ 7:47 am
You'll have to be more specific about what doesn't work for you
geposted Wed 03 Aug 22 @ 8:06 am
To explain everything I would have to write a novel, I could only show it via team view!
Atomix should test extensively here to determine the many errors
geposted Wed 03 Aug 22 @ 8:22 am
