Topic: Disable POI Auto Creation
mrcheckPRO InfinityMember since 2020
Each time I open a new video for the first time, Virtual DJ analyzes the file and automatically creates several POIs. Is there a setting to turn that off?
For my purposes, I manually create a Mix "Full" Start Point and Mix "Full" End Point and delete all the other POIs. So for every new file, I start by opening the file, see no POIs, then I watch the POIs get automatically created so that I can then go in and manually delete them all.
It would save be a good bit of time if there were a setting to tell it not to create them in the first place. Unfortunately, so far, I haven't found such a setting. Does it exist?
Thanks,
Check
geposted Thu 05 May 22 @ 3:58 am
