Hi peepz,
why is it, that VDJ automatically sets a certain gain position, that even when I change it on my SX2 it switches it back to its original position after some time.
Then i have to move the knob to the programs position to get access back to gain.
Hope this describes it adequately.
Thanks
Thanks
geposted Sat 07 May 22 @ 3:49 pm
most likely you have auto gain ON
this will set your gain (on each track loaded) to a volume that prevents the track from clipping
if you don't want auto gain and know how to prevent clipping so your sound doesn't distort turn it off in options
geposted Sat 07 May 22 @ 3:53 pm
Thanks a lot, that worked!
Had to switch it off, due to Automix during dinner and have the gain quite low, due to low input level of my mic.
geposted Sat 07 May 22 @ 4:00 pm
