Hi,
I was wondering if it is somehow possible to show in the browser if a song contains cue points?
thanks in advance!
Patrick
thanks in advance!
Patrick
geposted Mon 09 May 22 @ 8:03 pm
Pretty sure this has been asked before and it's not possible.
geposted Mon 09 May 22 @ 8:47 pm
I have an out of app console program that can include or exclude a search for anything in the database [anything, cues without a name, tracks with markers, action cues with specified action]
[it makes playlists to work on in app]
i know database editing will never be recommended in any circumstances except with vdj itself, but it sure would be useful if vdj could give a read only version of the database with the api [with the warning "you'll be working with a 10 - 20+ mb string! don't expect to use it in a performance environment" ] we could go deep diving for data.
My non live app is available for windows on pm request.
geposted Mon 09 May 22 @ 9:45 pm
Locodog.. using your amazing, virtualfx and .. the cueQueryLoop that you wrote with it ..
could be a workaround.. since it writes cue info, to the tag editor, which can then be quick filtered or have color rules created.
geposted Tue 10 May 22 @ 5:52 am
doesn't apply here for ops case.
geposted Tue 10 May 22 @ 4:18 pm
