Hi
I'm looking for a little help.
I restarted playing around with Virtual DJ and my Hercules DJ Air+ under Windows 10.
All is working well so far but on the device there is an mic button. Unfortunately this has absolutely no effect within VDJ.
I checked the mappings within VDJ but I can't find anything about it.
Does anybody here has any idea?
Thanks so far
Thanks so far
geposted Tue 10 May 22 @ 6:40 am
https://virtualdj.com/documents/Hercules%20RMX2%20-%20VirtualDJ%208%20Operation%20Guide.pdf
-----> Microphone, Side 13
geposted Wed 11 May 22 @ 11:11 pm
Hi
It's the mic button that has no effect within the VirtualDJ
I tried to map it manually but it's not even recognized pushing on it
So I changed the magic button to swap micro on or off - at least that is working and helps me a lot
Thanks
Thanks
geposted Mon 16 May 22 @ 10:47 am
