Hello,
Do you know the command to light on/off a button when it's pressed ?
I checked on the wiki I didnt find anything.
In my case, I own a numark mixtrack platinium fx. When you push the button "flanger" it become red.
I assigned this button to another command. The command works, but the button is not lighted anymore when we press on/off.
Do yo have any idea ?
thank you
thank you
geposted Thu 12 May 22 @ 11:37 am
It depends if the command you use can be validated as true or false (which is often on or off)
geposted Thu 12 May 22 @ 4:04 pm
Hello,
I use this mapping, because I want to use the crossfader live with the 4 channels.
FX_HPF : deck 1 leftcross
FX_ECHO : deck 3 leftcross
FX_Flanger : deck 2 rightcross
FX_Phaser : deck 4 rightcross
I want to see when a crossfader is activated or not
I tried for exemple : deck 1 leftcross ON
But there is still no lights on the buttons when it's activated and desactivated.
When I push the button FX_LPF, just to see a standard behaviour, I can see :
- When I hold the button it send "ON"
- When I release the button it send "OFF" by default
geposted Mon 23 May 22 @ 3:51 pm
Which controller is that ?
Depending on the controller firmware it may not be possible to control these leds directly, or it may not be possible to control all of them at the same time.
geposted Mon 23 May 22 @ 4:01 pm
I found the solution !
I just edit this part :
LED_FX_HPF : deck 1 leftcross
LED_FX_ECHO : deck 3 leftcross
LED_FX_Flanger : deck 2 rightcross
LED_FX_Phaser : deck 4 rightcross
geposted Mon 23 May 22 @ 4:04 pm
Hi phantomdeejay
it is numark fx platinium mixtrack =)
geposted Mon 23 May 22 @ 4:05 pm
