Topic: Set Specific Key Using Custom Button
Hi all,
I see there is a 'set_key' keyword to set a song's key related to the current song's playing key but is there a way to set a song to a specific key in a specific octave related to the current playing key using an onscreen skin custom button and change the color of it?
I can for example use set_key "C" but 2 problems.
First I can't change the skins button green when that happens.
Second I can't tell where that "C" is in relation to the octave that's playing.
For example if a song is playing in whatever key and I want to click a custom button on the screen and start playing in an octave below C while changing the color to that button green.
Thanks for any help.
geposted Sun 15 May 22 @ 9:48 pm
set_key will choose the closest key.
I'm not sure if it would ever make sense to choose another octave since that would mean the song was shifted more than 6 semitones which most likely would make it sound pretty bad (especially drums)
Will fix for next update that it also shows the state when the key is the same as the set_key button
geposted Mon 16 May 22 @ 5:36 am
