Can the length/time of the video transitions be adjusted, as I do transitions hitting the TRANSITION button myself. Ideally I want to lengthen the time for these, but really cannot find means to do so. Any help would be greatly appreciated.
Thanks...
Thanks...
geposted Mon 16 May 22 @ 2:06 am
The button on the skins usually doesnt have any duration parameter, so it's using the default value.
If you want to change/extend, you will need to either edit the skin or use some custom skin/keyboard/controller button assigned as..
video_transition Xms where X is a value in milliseconds.
geposted Mon 16 May 22 @ 11:07 am
