Hi all,
I would like to assign 2 sliders of a vst to a touchstrip and use 2 pads to decide if the touchstrip should control the first slider, the second slider or both at the same time. Using
Touchstrip:
var 'turnadoA' 0 ? effect_slider 'turnado' 15 & var 'turnadoB' 0 ? effect_slider 'turnado' 28
Pad 1:
var 'turnadoA' 1 ? set 'turnadoA 0 : set' turnadoA '1
Pad 2:
var 'turnadoB' 1 ? set 'turnadoB 0 : set' turnadoB '1
this happens:
I turn on pad 1, I move the touchstrip, the slider moves, I turn off the pad 1 and the slider will not move. Correct
I turn on pad 2, I move the touchstrip, the slider moves, I turn off the pad 2 and the slider will not move. Correct
I turn on pad 1 and pad 2 together, only the slider of the first command moves (var 'turnadoA' 0 ? effect_slider 'turnado' 15)
while the slider of the second command (var 'turnadoB' 0 ? effect_slider 'turnado' 28) not move.
Could someone tell me what am I wrong and if I can get what I want?
Thanks to anyone who wants to answer me.
Touchstrip:
Pad 1:
Pad 2:
this happens:
geposted Fri 20 May 22 @ 1:36 am
you didn't account for all cases
thing a true ? thing b true ? both things : only first thing : thing b true ? only second thing : nothing
but now we have brackets in scripts, you could just do this
( var 'turnadoA' 0 ? effect_slider 'turnado' 15 : ) & var 'turnadoB' 0 ? effect_slider 'turnado' 28 :
geposted Fri 20 May 22 @ 1:43 am
I hadn't thought about the departures that allow us to divide the two cases, I'm still used to when they weren't present :) I tried and of course it works!
Thanks for your time Locodog!
geposted Fri 20 May 22 @ 1:50 am
