I bought a new laptop in February that came preloaded with Windows 11. Installed latest version of VDJ, and paired it with my Pioneer DDJ-400 controller. When hooked up to my 18" subwoofer and two 15" tops (through the controller), there is no bass. When I use a buddy's laptop with Windows 10 and RekordBox, the bass comes back (that rules out bad controller or speakers). We also tried his DDJ-400 controller with my laptop - there was no bass (so that also rules out a bad controller). When I use my girlfriend's laptop with Mac OS and virtual DJ, the bass also comes back. To determine if it was my laptop's audio card, I installed RekordBox and paired with my controller. The bass comes back. (This rules out bad laptop audio card or hardware)... so the only scenario where the audio contains no bass is when VDJ is paired with my laptop. Other DJ software works fine. Since my buddy had Windows 10, I am guessing that the problem is compatibility with Windows 11? And perhaps since most people haven't switched over to Windows 11 yet, there isn't much out there on this yet? I am banging my head on what is the problem here. When I ask for help from VDJ technical support they just deny that could be the problem Is anyone else having this problem when they hook up to a subwoofer? You won't notice the problem even on a monitor. You'll only notice once you try to hook up to a bigger speaker. Thanks in advance.
geposted Mon 23 May 22 @ 10:46 pm
I will try to downgrade to windows 10 and see what happens then. But what a pain
geposted Tue 24 May 22 @ 1:33 am
I am using Windows 11 for quite some time now.
No issues with bass either.
So, whatever your issue may be, it's not due to the OS.
It could potentionally be an OS setting though (especially if you're using WASAPI drivers instead of ASIO)
Therefore better check out all sound settings of your laptop/OS first before going back to Windows 10
geposted Tue 24 May 22 @ 7:31 am
Thanks for the reply Phantom. Just curious - have you been hooking up to a subwoofer and large PA system? I wouldn’t have noticed the difference myself until I did that. As for the sound settings in the laptop, there really isn’t much to adjust besides the equalizers in the new MaxxAudioPro app for windows 11. It has very minimal effect however. Have you tried VDJ on bigger speakers? I’m just really stumped here and about to give up. I don’t want to switch to rekord box because I like the real-time stems on VDJ. But that’s just what I might have to do. Again thank you
geposted Tue 24 May 22 @ 5:06 pm
Also - the only option for the DDJ-400 is a wasapi driver. There is no option for ASIO. But I’ve ruled that out because when a different laptop is plugged into the controller, it doesn’t have the problem. Still using same driver.
geposted Tue 24 May 22 @ 5:08 pm
Yes, I have made gigs on large PA systems with Windows 11.
Try to change "exclussiveAudioAccess" setting in VirtualDJ to see if that helps.
Windows 11 have a few new "features" for soundcards, so there's a possibility that on your system the driver has an option enabled that's disabled (or not present) on another one.
geposted Tue 24 May 22 @ 6:43 pm
Windows 11 here and I have plenty of bass.
From what you wrote it seems like you only have one sub, is that right?
If that's the case, maybe the issue is with phase, as with a mono sub the bass will disappear if the left and right audio channels are out of phase.
geposted Tue 24 May 22 @ 7:02 pm
PHANTOM DJ !!!!!!! YOU ARE THE MAN!!!!
exclusive audio setting fixed it.
Thank you so much!!!!
geposted Tue 24 May 22 @ 7:58 pm
Hello everyone, I also have problems with Windows 11 and a new Legion laptop... when playing, the songs always hang for a second... what can I do? Thanks
geposted Tue 04 Oct 22 @ 8:25 am
can you tell me exactly where? in windows 11 or directly in the virtual dj menu
geposted Tue 04 Oct 22 @ 8:49 am
Sokac, go into settings in VDJ, type in search bar exclusive audio. It will come up first choice. Toggle onto yes. You want the software to have exclusive audio. If that’s not the issue then I would ask if you are streaming your tracks or have you downloaded them? If streaming this could be the problem. Troubleshoot by using only downloaded tracks vs using only streaming tracks.
geposted Tue 04 Oct 22 @ 12:55 pm
Thank you, I'll try my luck and get in touch... p.s. I only use downloaded tracks
geposted Tue 04 Oct 22 @ 1:47 pm
I once had a similar issue with my setup where certain software just didn't play nice with my hardware.
Have you tried reaching out to other VDJ users to see if anyone else has encountered this bass problem specifically with Windows 11? Sometimes, collective troubleshooting can lead to surprising solutions.
geposted 5 days ago @ 1:20 pm
