Topic: Update issue
Just updated to the new version 6954 . When loading the song VDJ just shuts down. Never happened with the previous version
geposted Tue 24 May 22 @ 12:14 am
Which cpu do you have?
Does it also happen with mathEngine disabled?
Having same issue. Only time it doesn't crash is if I have Mathengine disabled and can't use stems 🤦
Asus vivobook x512
64bit
Intel I7 processor
Could you try the following?
-Open VirtualDJ and in options set 'createMidiLog' to yes and enable mathEngine again
-Restart VirtualDJ and try to load a song
After it crashes, check your Documents\VirtualDJ folder for a file named 'Log Report.txt' and reply with the contents of that file.
Thanks
I can confirm the crash on build 6954 on Surface 7, Core i5, 8 GB ram, Windows 11. But it only crashes when turning the stems switch on. Without stems "on" the songs load without any problems. In the Log Report.txt are no entries for the crashes.
Except for the crashes, when createMidiLog is enabled it should log some other useful values for us to find out why it happens. (starting with "math cpu:")
@adion hope this helps.
--- 2022/05/24 - 18:10 (6954)
[18:10:15] Midi out device detected, name:Microsoft GS Wavetable Synth mid:1 pid:27
[18:10:26] math cpu f: brgconv:avx512_core - - 0:16
[18:10:26] math cpu f: brgconv:avx512_core - - 0:32
[18:10:26] math cpu f: brgconv:avx512_core - - 0:64
[18:10:26] math cpu b: avx512_core 1:16 1:16 1:16+0:16
[18:10:26] math cpu e: brgconv:avx512_core - - 0:16
This latest update is crashing the program as soon as you load the song onto the deck. Anyone else experiencing this and have a clue on how to fix it.
Please try update 6959
@adion
Build 6959 is loading the songs without a crash on on my Surface 7 with "stems cpu mode".
Well done
Thanks a lot :)
