Hi,
I am trying to assign various loop out effects to pads for quick access
The loop out has the following:
Length:
Mode:
Mode Peram:
Count:
Stop
Slip
Video
padfx 'loop out' 1bt fade 80% 50% works but I cannot figure out the correct syntax to change the mode
Can anyone help
Thanks in advance
Length:
Mode:
Mode Peram:
Count:
Stop
Slip
Video
Can anyone help
Thanks in advance
geposted Wed 25 May 22 @ 2:28 pm
mode is just slider position
geposted Wed 25 May 22 @ 2:31 pm
Thank for that info.... My basic one now works... Easy when you know how.
I wanted to get a bit more creative so I came up with this
padfx 'loop out' 1bt 1% 80% 50% & padfx "flanger" 100% 80%
It works but once it's completed the flanger effect stays on. Is there a way to turn it off?
Thanks in advance
Thanks in advance
geposted Wed 25 May 22 @ 3:36 pm
since loop out self terminates, after all your current script set up a rsi to monitor loop out, when off kill flanger & kill the rsi
geposted Wed 25 May 22 @ 3:54 pm
Thank you for the reply.
What is an RSI and where can I read about how to use them?
I've only ever dabbled in simple scripts before so any help would be appriciated.
Thanks in advance
Thanks in advance
geposted Wed 25 May 22 @ 4:01 pm
repeat_start, repeat_start_instant, repeat_stop
https://virtualdj.com/forums/223743/General_Discussion/Script_School.html?page=3.80
geposted Wed 25 May 22 @ 4:52 pm
