Topic: effect_stems off
The script: effect_stems off
It works when it's mapped to a button, but not when I put it in the LOAD event of my controller mappings.
Basically, if I was running effects on just one stem, I want to automatically clear that when I load a new song so that effects now run on the whole song again. Any workarounds? Is this a bug?
geposted Sun 29 May 22 @ 12:44 pm
in options set ResetStemsOnLoad to All
geposted Sun 29 May 22 @ 2:36 pm
effect_stems vocal off works here, when added to the keyboard ONSONGLOAD .. currently using ver 6969 and has always worked.
check if you need brackets to isolate queries in the script, if you have multiple queries, which could cause some parts of the script from being executed.
geposted Sun 29 May 22 @ 6:09 pm
Already set. This unfortunately does not reset the "effected stems" parameter. But thanks anyway!
That did it! It works in the keyboard ONSONGLOAD event but not the controller LOAD event. Strange! Thanks for the workaround.
geposted Sun 29 May 22 @ 10:14 pm
