Topic: DENON MC7000 FX_Assign_Button
gis_csPRO InfinityMember since 2010
Hey,
Can you please store the FX Assign button individually (1-4) as a command. Currently, all 4 keys have the same command.
geposted Mon 30 May 22 @ 7:15 pm
You just need to query the deck that the pressed button is assigned to.
action_deck x ? ActionForDeckX : ActionForAllOtherDecks
For FX1_ASSIGN button the action assigned for all decks is effect_clone 1 (clone the effects of Deck 1 to this deck)
So if you want the FX1_ASSIGN button of Deck 2 to perform some ActionA and the rest to still perform the global action, you need to assign as ..
action_deck 2 ? ActionB : effect_clone 1
or individual actions for each one of the 4 buttons..
action_deck 1 ? ActionA : action_deck 2 ? ActionB : action_deck 3 ? ActionC : ActionD
If you want some specific actions, provide these in details and we can help with the code
geposted Tue 31 May 22 @ 5:58 am
Thanks for your help.
The Assign buttons should be assigned effects that work as selected on each deck as follows: Assign Button 1= filter_selectcolorfx 'filter' activate | Assign Button 2 = filter_selectcolorfx 'flanger' activate | Assign Button 3 = filter_selectcolorfx 'echo' activate | Assign Button 4 = filter_selectcolorfx 'cut' activate. The filters should be selected at the touch of a button as with the Pioneer DDJ 800/1000.
geposted Wed 01 Jun 22 @ 2:58 pm
FX1_ASSIGN :
action_deck 1 ? deck all filter_selectcolorfx 'filter' : action_deck 2 ? deck all filter_selectcolorfx 'flanger' : action_deck 3 ? deck all filter_selectcolorfx 'echo' : deck all filter_selectcolorfx 'cut'
The above script is for the left-side FX Assign buttons. You can map the FX2_ASSIGN with 4 more Color FXs if you want.
geposted Wed 01 Jun 22 @ 6:09 pm
Great, you understand your job! Thank you
geposted Wed 01 Jun 22 @ 8:24 pm
