On VDJ all knobs seem to show (shadow toggle) on main screen next to each button> THIS CAUSES the sound to fluctuate from low to loud. Which is a problem when mixing with different levels up and down. HELP
geposted Thu 02 Jun 22 @ 5:08 am
[ would appreciate a response of my post regarding volume issues
geposted Fri 30 Sep 22 @ 11:17 pm
probably need to adjust this in options
controllerTakeoverMode
Defines how sliders and knob are behaving when the value on the controller doesn't match the value on the skin: "Instant" means as soon as you touch the slider on the controller, VirtualDJ will use the controller's position. "Pickup" means that the controller's slider has no effect until it reaches the current skin's position, at which point both positions become linked again. "Gradual" means that when you move the controller's slider, it will moves the skin's slider in the same direction to gradually match both positions
geposted Sat 01 Oct 22 @ 12:13 am
