hello, I Have two technics 1210 connected to a Mixars duo using Virtual DJ. If I try to mix an mp3 and a real vinyl the volume differences are huge! is there's something to amplify Vinyl volume at the same level of mp3? Thank you
geposted Thu 02 Jun 22 @ 2:43 pm
Analogue input at the Mixar mixer?
if its HUGE difference, you might have connected the turntable to Line In instead of Phono in at the mixer.
And adjust the volume of the analoge input using the mixers gain or trim knob
geposted Thu 02 Jun 22 @ 2:47 pm
the connections are correct. The problem is the output. When I compare the waveforms of the vinyl and the mp3 on virtual dj , the differences are huge! I've tried to connect a behringer phono preamp between the turntable and the mixar but it all went distorted.
geposted Thu 02 Jun 22 @ 3:28 pm
waveform from real vinyl?
you mean you are playing it through VDJ?
geposted Thu 02 Jun 22 @ 5:05 pm
Yes
geposted Thu 02 Jun 22 @ 5:24 pm
