Topic: Using iCloud
I recently moved (via VDJ) my music database to iCloud Drive (so my tunes are on all my devices) but I can’t find a way to navigate to this folder so I can add it as a favourite.
The only way is via Finder/drag & drop. Naturally that doesn’t give me any BPMs, keys, etc.
geposted Thu 02 Jun 22 @ 4:34 pm
I don't use iCloud Drive personally, but I believe it's in ~/Library/Mobile Documents/com~apple~CloudDocs/
You should be able to navigate there in the VDJ file browser and make the folder a favorite.
geposted Fri 03 Jun 22 @ 2:20 am
That worked perfectly. For anyone else having issues - add in “show volumes” in settings. Computer / users / your name / library / mobile documents and it’s lurking in there.
You’ll need to rebuild your Smart Folders too. This is a little complex as you can’t copy and paste. The squiggle~ is made by pressing option n. And needs to be /users/your name/mobile documents/com~apple~Clouddocs/music (the name of the folder which resides in my iCloud Drive).
Thank you. I hope I can help others too with this!
geposted Mon 06 Jun 22 @ 1:36 pm
