When using automix, there is an amount of BPM difference set to where it will match the BPM to the next song as its transitioning. Can i adjust this setting or omit the limit some how? I have the smartPlayLimitPitchRange turned off and it still seems to have a limit. I didn't notice any other setting. Thanks
geposted Fri 03 Jun 22 @ 4:33 pm
smartPlayLimitPitchRange setting is related to a completely different function of the software.
The only limit during automix is the current pitch range.
I just tested with pitch range +/-50% and automix was very happy to beatmix a transition from 100 to 133 BPM.
geposted Fri 03 Jun 22 @ 6:01 pm
Mine is set at 100 (I changed it to 80) and I just tested it...the bpm of first song was 106 and the second 127..and it didn't move at all..it stayed at 127 during the transition. I tested the slider and it moved the 100 so idk...very odd if there is no other setting it could be thats causing it. I attached an example of one i just tried.
geposted Fri 03 Jun 22 @ 6:23 pm
