Im working on a project where i use several poi macros.
Sometimes i play the song and the macro just doesnt work, then i rewind the song and play the exact same section again without having anything changed and now it works.
Is there some functionality i am not aware of or is this a bug?
Example:
https://youtu.be/SMA4QaV3DDM
Example:
geposted Sun 12 Jun 22 @ 2:49 pm
You're not crazy, I've seen this happen too. I ended up stopping using POIs and just use scripted macros from my Novation Launchpad instead.
geposted Thu 23 Jun 22 @ 10:50 pm
it happens to me sometimes as well has for a long time ... usually happens if i move eq or some other control on my controller right before the poi should activate
geposted Thu 23 Jun 22 @ 10:59 pm
