Hi, Vj2021 keeps crashing when loading a song in ? Then one of the decks has no sound so needs to be restarted but will do it again. I’ve reinstalled but no joy ! My mate is having the same problem ! We are on a Mac Pro 16” 2019 and the new M1 16” ???
geposted Fri 17 Jun 22 @ 7:07 am
Is it happening with a specific song, or any song?
Does the song happen to have video too?
geposted Fri 17 Jun 22 @ 7:16 am
I always play video tunes so yes it’s music videos but can be any MP4 video. It can happen anytime also when a karaoke track is playing, only why to get round it is not to load anything is while singing
geposted Sat 18 Jun 22 @ 8:32 am
Also it’s okay on windows it’s just Mac
geposted Sat 18 Jun 22 @ 8:38 am
Could you try the latest early access build 7014?
https://virtualdj.com/download/build.html
geposted Sat 18 Jun 22 @ 9:01 am
Thanks might have too ! it's only been doing it a few weeks since an update, was hoping another might fix it
geposted Sat 18 Jun 22 @ 9:21 am
Rolled it back but still crashing ! Looks like it’s back to windows :(
geposted Sat 25 Jun 22 @ 8:12 pm
Only thing I can find is that the Codecs AAC, av01 video music mp4 seems to be the problem when loading this type of file but seems only to be loading for the first time
geposted Sun 26 Jun 22 @ 9:16 am
Did you try 7021?
geposted Sun 26 Jun 22 @ 9:20 am
Yes mate and 7014 :( don’t really want to use a windows laptop again but my old HP works okay.
geposted Mon 27 Jun 22 @ 5:00 am
Found the problem, it’s AAC, av01 Video files VJ doesn’t like them so I’ve converted them all. 👍
geposted Mon 27 Jun 22 @ 6:17 pm
If you can keep one and share it with dev staff
geposted Tue 28 Jun 22 @ 6:54 am
