Forum: VirtualDJ Plugins
Topic: Hardware vs. software fader position?
Is there anyway to get the hardware position of the fader (or any other dial/fader) when it's out of sync with the software position?
For example if you drag the fader to 0 in the software it will show the hardware position faded out in it's original position.
I have a few scripts that manipulate the track volume level so i'd like to be able to flash an LED when they're out of sync.
Thanks.
geposted Fri 17 Jun 22 @ 11:36 am
It's not possible for all faders.
It is only possible for pitch fader, where you can use the action
param_equal pitch_slider pitch ? on : blink
geposted Fri 17 Jun 22 @ 11:48 am
Great thanks, I'll give that a go later.
I knew it would be something quite simple!
geposted Fri 17 Jun 22 @ 11:51 am
