Topic: Tap Button
Hello, I will be having a tough time explaining this but I will try my best.
VDJ has a problem sometimes with specific songs, it sets the bpm to "half beat" if that is how I can say it. However, in earlier versions of VDJ I used to double the bpm on these songs (exp from 95 to 190) then set a cue on that "half beat", reset bpm to 95, click alt+1 to go on cue 1 and then click the button "Tap" and the beat would snap and be corrected on the whole song. I really don't know if anyone could follow what I'm saying but it's easy in practice.
But in the newer versions the tap button is gone, there is one when I right click on a song and go into bpm options, but that button can't do what I'm trying to.
I tried my best, hope someone understands and have a clue how I can fix it. Thank you!
geposted Fri 17 Jun 22 @ 10:41 pm
You can simply use the following actions
adjust_cbg +0.5
adjust_cbg -0.5
and save yourself a lot of time..
geposted Sat 18 Jun 22 @ 9:51 am
Oh damn that was exactly what I was looking for, thank you so much!
geposted Sun 19 Jun 22 @ 5:24 pm
