Hello guys,
I’m facing a problem with virtual dj, infinity subscription. I just bought a M1 MacBook Pro Monterey 12.2 16 gb ram and i use, 2 cdj2000nxs2 and a djm900nxs2.
The issue is that everyday, there is at least one freezing while playing. Every equipment is updated to the latest firmware and drivers.
Any idea of what’s going on?
geposted Sun 19 Jun 22 @ 8:50 pm
Can you try a different USB hub?
In most cases issues like this are related to USB C hubs
geposted Sun 19 Jun 22 @ 9:30 pm
I’m using an type c usb hub only for the cdjs, the mixer is connected by itself to another usb c port, not in the hub.
Should i try to connect everything straight to the laptop, with no hub at all?
geposted Sun 19 Jun 22 @ 9:51 pm
I just sold a I5 MacBook Pro 2017
and bought Asus ryzen 7 with 3060
macbook got a problem with auto light detectors on clubs because lights contrast.
i can use without freezes covering light detectors...
but it must be very frustrating to spend $2000 on a laptop and have these things happen to you.
It's not a virtual dj problem, it's an apple problem.
trust me. that I have sold my macbook for this.
I know it is not the same model, but I am almost 100% sure that it is this problem
tell us if you solve the problem
geposted Mon 20 Jun 22 @ 1:33 am
So, today, i connected only with the hub the 2 cdjs 2000nxs2, using their soundcard and there was no problem.
But the sound quality was different, I prefer the one from the mixer.
What else should i check so as to connect the mixer and play with its soundcard?
geposted Tue 21 Jun 22 @ 12:01 am
