When removing duplicates it is removing the top one it use to remove the bottom song
geposted Mon 20 Jun 22 @ 8:22 am
I have already pointed this out recently.... Is in progress I suspect.... :-)
https://virtualdj.com/forums/247084/VirtualDJ_Technical_Support/Automix_Options__Remove_Duplicates__changed_function.html
geposted Mon 20 Jun 22 @ 8:28 am
It should have been changed in the latest early access release
geposted Mon 20 Jun 22 @ 9:05 am
It says it's fixed, but it doesn't really work in my test yet...
geposted Mon 20 Jun 22 @ 9:14 am
