When playing on one deck then loading on the other deck it sometimes will just crash and restart with one deck not working so needs to be restarted. I’m using a 2019 16” MacBook Pro and my friend is using a MacBook Pro M1 16” with the same problem ! But it’s okay on my windows laptop. We have taken Vj out completely and started from scratch, it can be any MP4 at any time so I can’t pinpoint the problem, I’m even using the default basic skin now ???
geposted Tue 21 Jun 22 @ 8:10 am
Can you try early access build 7021?
https://virtualdj.com/download/build.html
geposted Tue 21 Jun 22 @ 8:13 am
