Topic: Effect buttons in FX
Updated windows and did som config due to heatproblems and CPU load was way to high.
After that my DDJ-RR only response on effect button 1, while buttons 2 and 3 scroll which effect to use on button 1 Up or down.
So before I had preset and use of 3 effects on the three buttons. Since I'm not a code master I need help to reset the buttons how they work before. Neither don't the slider twitch knob work. Don't change any fx at all
geposted Thu 23 Jun 22 @ 2:15 pm
Edit.
Shift + Beat [Auto] was the trick. Micht tap it without knowing it. Thx
Select 'factory default' on the mapper tab in config for the controller then to go back to default.
