Topic: sound buttons
In VDJ volume nobs show shadow line which effect sound controls. Why is this happening?
geposted Sat 25 Jun 22 @ 4:24 am
Shadow sliders will show up when the slider position in software doesn't match the one on your controller.
This usually will happen if you click on the GUI to alter slider positions or if you change their values via script (while the controller is connected)
