Topic: Timecode - First Attempt
Hey,
I am new to Virtual DJ and I am trying to use my Vinyl turntables on VDJ. Currently my hard ware is Stanton ST8 80s and Behringer NOX101 - and am having issues as the system doesn't appear to recognise the vinyl. (The Vinyl I have are Sterato's ) but I have been told they should be compatible.
When I check on the settings - Under the Timecode section, it doesn't show ay signs of life. And it is frustrating.
B
geposted Sun 26 Jun 22 @ 12:24 am
djcelPRO InfinityModeratorMember since 2004
Can you post a screenshot of your timecode window in virtualdj options and another one with the sound setup?
geposted Tue 28 Jun 22 @ 6:50 am
