Topic: Auto mix editor hangs
hiltraPRO InfinityMember since 2011
I'm having irregular problems with the auto mix editor. When I open the auto mix editor and I have several songs in the auto mix list (at least 60 or 80 songs), the editor sometimes either completely hangs (so I have to re-open it) or when I click on "Play" in the editor it only produces some scratchy noises (so I have to re-open it again) or it hangs after I moved a song to change the overlapping area (then, I also have to re-open it). Sometimes, I am re-opening the auto mix editor two or three times before I can use it without any problems.
I am using the latest version of Virtual DJ on a quite recent Windows PC.
Is anyone having the similar problems? Any clues how to avoid the problems?
Thanks a lot in advance!
geposted Wed 06 Jul 22 @ 7:25 pm
geposted Fri 08 Jul 22 @ 12:03 am
Thanks a lot for the hint!
I will try this and see what happens at the next party :-)
geposted Sat 09 Jul 22 @ 4:36 pm
