Topic: BCD 3000
Dear friends,
I am not able to use my controllers on my BDC3000 any longer. The board lights up as it has in the past, but since my Microsoft pc updated to windows 10, they no longer work. I can control all faders and volume from the VDJ screen, but not the controller itself. Any suggestions?
Thanks, DJ ECUTT
geposted Thu 07 Jul 22 @ 11:47 pm
user8902606 wrote :
Any suggestions?
Yes - buy a new controller. The BCD3000 is 15 years old.
It was a nice controller though :p
Unfortunately it was not usb compliant audio or midi, so it required drivers to function properly, and it's indeed unlikely that Behringer will update the drivers for windows 10 at this point.
Thanks, guys for your reply. Any suggestions on which controller is compatible with windows 10 or will work best?
Thanks guys for your input. I'll try the software again and go from there! If that doesn't help, I'll have to upgrade!
