Topic: Novation launchpad mini
Hola buenas saludos a todos. Tengo una consulta cuando conecto el controlador novation launchpad mini , lo puedo mappear pero el problemas es que no me enciende ningún led del controlador.
geposted Fri 08 Jul 22 @ 4:17 am
You need to also map the LED for each pad also.
So if you have PAD_7_1 mapped to do something.. like deck 1 play_pause
then you also need to Map:
LED_PAD_7_1 to configure the LED.. to maybe something like deck 1 play ? color 'green' : color 'red'
(LED is green when playing, and red when stopped)
If the LED is NOT mapped then it will be in an OFF state.
