Topic: VDJ 8.4 b5874
Just built a new desktop installed windows and want to install the same 32bit VDJ version as in my older desktop. Can't see it in older downloads, anyone got a link please must be 8.4. thanks
geposted Wed 13 Jul 22 @ 12:34 am
why do you need the old version?
https://virtualdj.com/download/build.html
Telly Media should still work with the latest update.
You may need the 32-bit version download, but otherwise it should work fine.
I have it. if it's OK with VirtualDJ Support you can PM me I'll send it to you.!!!
